DIMM Temps Not Being Displayed
Postby chrimen » Wed Jan 27, 2021 12:42 am
I'm able to choose the DIMM temperatures from HWINFO and add them , but they display as 0.
HWINFO displays the temp, but GOverlay doesn't.
I get the following error in the logs:
1/26/2021 7:29:29 PM:Missing sensor: HW.5af50dea1fe71ae2b6323ba88efdab72:DIMM2 Temperature:°C
1/26/2021 7:29:29 PM:Missing sensor: HW.5af50dea1fe71ae2b6323ba88efdab72:DIMM3 Temperature:°C
Why does it say missing the sensor and how could I fix that?
Thanks in advance.
chrimen
Re: DIMM Temps Not Being Displayed
Postby TheLaGmAn » Wed Jan 27, 2021 1:29 pm
is this after you hit "save and apply"?
Also, try the newest beta
Postby chrimen » Sun Feb 07, 2021 10:45 pm
I have the newest beta and I hit save and apply, but it still shows this error
2/7/2021 5:45:12 PM:Missing sensor: HW.5af50dea1fe71ae2b6323ba88efdab72:DIMM3 Temperature:°C
2/7/2021 5:45:12 PM:Missing sensor: HW.5af50dea1fe71ae2b6323ba88efdab72:DIMM2 Temperature:°C
chrimen
Postby TheLaGmAn » Mon Feb 08, 2021 2:33 am
i cant reproduce it, but pick the sensor again, not just save and apply
Postby 7egacy » Thu Feb 18, 2021 8:05 pm
I have the same problem since3 Months. HwInfo and GOverlay are up2date (beta Versions)
7egacy
Postby TheLaGmAn » Thu Feb 18, 2021 8:36 pm
only with dimm?
Postby 7egacy » Mon Feb 22, 2021 8:00 am
Yes, other Sensors from HWInfo works fine. I use an Asus Crosshair VIII Dark Hero and Dimm Temps in HWInfo works
7egacy
Postby 7egacy » Fri Mar 05, 2021 3:14 pm
No Solution?
7egacy
Postby TheLaGmAn » Fri Mar 05, 2021 4:29 pm
we will need to do a teamviewer session because i cant reproduce it myself to fix it.
if you are available, contact me at support@goverlay.com
