Energy Saving Mode
Re: Energy Saving Mode
Postby Sash83 » Tue Dec 22, 2020 1:51 pm
I startet the Software and then connect the Display. The Log is from this Point.
I warnt to try another cable this evening.
Sash83
Postby TheLaGmAn » Tue Dec 22, 2020 2:07 pm
okay, then i will need a video of the issue because im not understanding it.
energy save mode will appear if the device is not receiving any new data to be displayed or it reconnects.
the first picture you sent only seems to have 1 sensor which displays mhz, if that data does not change overtime, the display will eventually go into saving mode because nothing new is being requested to be displayed since that sensor number isnt changing
Postby Sash83 » Tue Dec 22, 2020 5:36 pm
Cable, other USB Port, other PC, nothing work.
Video
VID_20201222_183729.mp4
Sash83
Postby TheLaGmAn » Tue Dec 22, 2020 6:35 pm
okay, contact me at support@goverlay.com , we will need to do a teamviewer session to check a couple of things
Postby channyein » Thu Apr 08, 2021 10:36 pm
Any luck? I have same problem.
channyein
Postby TheLaGmAn » Thu Apr 08, 2021 11:46 pm
what problem are you having?
Postby channyein » Thu Apr 08, 2021 11:53 pm
Same problem like him.Screen shows "Energy saving modes. Run goverlay to srart" and some random flash on it. Same as the video he uploaded.
channyein
Postby TheLaGmAn » Fri Apr 09, 2021 12:24 am
contact coldtearselectronics@gmail.com regarding this issue
Postby Sash83 » Fri Apr 09, 2021 4:03 pm
After several attempts with flash programs and so on, I finally got a new board in exchange.
Was very easy to swap.
Sash83
