Latency Ping Destination ?
Postby kultakala » Sun Nov 22, 2020 3:28 pm
I am using the latency function and it mostly shows quite high latencies (between 40 and 200 ms) although every manual ping i try has always a latency lower than 30 ms.
Which IP address is used for testing the latency and is it possible to change it ?
Thanks!
kultakala
Re: Latency Ping Destination ?
Postby TheLaGmAn » Fri Nov 27, 2020 11:39 pm
It uses www.google.com as default but you can change it in Sensors > Latency
Postby kultakala » Wed Dec 02, 2020 6:20 pm
Didnt notice the sensor pane at all!
Thanks a lot, thats what i looked for :-)
kultakala
Users browsing this forum: No registered users and 27 guests
