"No DX GAME"
"No DX GAME"
Postby Elric8/2 » Tue Nov 03, 2020 8:26 am
Hi, sometimes i have this message for a few second on the screen "No DX GAME"
Is it normal?
Elric8/2
Re: "No DX GAME"
Postby TheLaGmAn » Tue Nov 03, 2020 2:06 pm
The message would indicate that a game was running and now not anymore.
If you werent on a gaming session, check first if you see any message regarding a game starting first, if so, thats the game provoking it, if you dont see that screen then there is something detected as a game (you can use rivatuner statistigs -rtss- to set it to ignore that .exe) but you do not have a gaming profile set up.
You can disable game detection completly by going into settings and change "enable whilegaming profile switch when a game is detected"
Re: "No DX GAME"
Postby Elric8/2 » Tue Nov 03, 2020 2:27 pm
if i disable game detection the osd will be the same all the time right? I only have one profile created so i guess that on't change anything?
Elric8/2
Re: "No DX GAME"
Postby TheLaGmAn » Tue Nov 03, 2020 5:25 pm
Yes, OSD shouldnt affect profile detection
Re: "No DX GAME"
Postby Elric8/2 » Tue Nov 24, 2020 4:32 pm
I guessed i missed something the message still displays
https://www.zupimages.net/viewer.php?id=20/48/af5z.png
Elric8/2
Re: "No DX GAME"
Postby TheLaGmAn » Fri Nov 27, 2020 11:38 pm
Thats not the option i was talking about, this one:
http://prntscr.com/vrjols
Re: "No DX GAME"
Postby Elric8/2 » Sat Nov 28, 2020 4:53 am
Ah great thanks
Elric8/2
Users browsing this forum: No registered users and 22 guests
