GOverlay and OpenHM can't see CPU temp
Postby calyster solaris » Fri Jun 17, 2016 1:53 am
hey guys i just changed my PC and on my my old PC everything worked fine on windows 7 but now on Windows 10 with an Asus Maximus Formula 8 i cannot find the sensor for my CPU temperature
the Bios indicate it clearly and same goes for HWMonitor but for some reason GOverlay and Open HM does not, i tried running it in administrator mode as it solved the problem of someone else but it changed nothing for me sadly
anyone might have an idea or if i can add the sensors from HWMonitor?
thanks for the help!
Last edited by calyster solaris on Fri Jun 17, 2016 7:26 pm, edited 1 time in total.
calyster solaris
Re: GOverlay and OpenHM can't see CPU temp
Postby TheLaGmAn » Fri Jun 17, 2016 5:38 pm
Can you try the standalone open hardware monitor app to see if it shows up in there?
Postby calyster solaris » Fri Jun 17, 2016 7:24 pm
i did and it doesn'T show me anything outside the load for the cpu
here is what i get from OpenHM and from CPUID HWMonitor
calyster solaris
Postby TheLaGmAn » Sat Jun 18, 2016 3:50 pm
Okay, so thats the problem, OHM is not showing you your CPU info for some reason so GOverlay will have that same issue.
You could switch to HWiNFO or any other of the apps but you will have to keep them running on the background.
Have you tried running OHM standalone app as admin?
Postby calyster solaris » Sun Jun 19, 2016 3:25 am
yes i did try it as admin but no change, i don't mind having to run other app in the background but how can i add them to the LCD display?
calyster solaris
Postby robb » Sun Jun 19, 2016 1:39 pm
You may want to try the lastest alpha of open hardware monitor http://openhardwaremonitor.org/files/openhardwaremonitor-v0.7.1.5-alpha.zip see if that finds your CPU temps
Postby calyster solaris » Tue Jun 21, 2016 6:52 am
robb wrote:You may want to try the lastest alpha of open hardware monitor http://openhardwaremonitor.org/files/openhardwaremonitor-v0.7.1.5-alpha.zip see if that finds your CPU temps
this one worked! thanks bud!
calyster solaris
Postby Jayson33 » Wed Jun 22, 2016 6:31 pm
robb wrote:You may want to try the lastest alpha of Core temp 1.2.1
see if that finds your How to monitor your CPU Temperature in Windows 10
I have installed HWmonitor could i shift to open hardware monitor ?
Jayson33
Postby Jayson33 » Wed Jun 22, 2016 6:41 pm
Here is my CPU TEMP SCREENSHOT
Please guide me should i change the application. Currently my CPU temp is 46 what is the optimial cpu temprature
Help me i am newbie
Dell core i5 2nd Gen E5430
4GB Ram
320 Hard disk
Jayson33
Postby TheLaGmAn » Wed Jun 22, 2016 9:25 pm
If the alpha works, by copying the openhardwaremonitorlib.dll file in that alpha into the GOverlay folder (replacing the old one), GOverlay should be able to get those sensors that you see in the OHM Alpha version.
Users browsing this forum: No registered users and 14 guests
