teamspeak Talker
Re: teamspeak Talker
Postby JPYZFR1 » Sun Jan 29, 2017 9:41 pm
Thanks my friend. I think that I'm the only one who finds bugs :D
Postby JPYZFR1 » Sat Mar 25, 2017 8:43 pm
I'm using last version 1.5.2
When i open teamspeak:
25-Mar-17 23:01:58:TeamSpeak - Connected!
25-Mar-17 23:01:56:Teamspeak - Trying to connect to TS Telnet
but teamspeak talker is not working and microphone icon is not changing to red.... Can you check it please?
When i close teamspeak:
25-Mar-17 23:04:52:TeamSpeak - Connection exception: No connection could be made because the target machine actively refused it 127.0.0.1:25639
25-Mar-17 23:04:51:Teamspeak - Trying to connect to TS Telnet
25-Mar-17 23:04:51:TeamSpeak - Handle Incoming Exception: Index and length must refer to a location within the string.
Parameter name: length: at System.String.Substring(Int32 startIndex, Int32 length)
at al.c(IAsyncResult A_0)
Postby TheLaGmAn » Sat Mar 25, 2017 11:54 pm
version of TS?
Postby JPYZFR1 » Sun Mar 26, 2017 8:09 am
version 3.1.3 (23-Mar-17 16:31:12)
qt version 5.6.1
Postby TheLaGmAn » Sun Mar 26, 2017 5:29 pm
TS 3.1 added a new feature to protect unwanted apps to connect to TS, it now requires the APP to have a key to connect to TS.
I added support for this in a new beta.
Update with the code
1.5.3_dfp
Once running, go to Sensors > TS
There you will see the steps to put the proper TS key.
See if it works.
Postby JPYZFR1 » Sun Mar 26, 2017 5:40 pm
Yes it's working. Thank you.
