Not working
Not working
Postby eric78 » Fri Jan 22, 2016 3:59 pm
Hi guys
I've issues with running the Goverlay,I've run previously Goverlay without the issues,now I've new PC and there I can't use or run Goverlay
Tried Goverlay Tester and here is screenshot of the Goverlay tester
And log export
Report generated at: 22/01/2016 15:48:02
------------- OS Info ------------
--> Version: 6.1.7601.65536
--> Name: Microsoft Windows 7 Ultimate
--> Windows is 64 bits
------------- File Drivers Check ------------
System32 located at: C:\Windows\system32\
LibUsb0.dll found
--> Version: 1.2.2.0
drivers\libusb0.sys found
------------- LibUsb Driver Status ------------
LibUsb Kernel version: 1.2.2.0
------------- Related Devices Connected ------------
--> LCDsysinfo for GOverlay
----> Service: libusb0
----> Description: LCDsysinfo for GOverlay
----> Manufacturer: Coldtears Electronics
----> DeviceID: USB\VID_16C0&PID_05DC\LCDSY
----> Status: 0
------------- Devices Detected ------------
Device: #0 (Coldtears Electronics - LCDsysinfo for GOverlay)
-> Pid: 1500
-> Vid: 5824
-> Product: LCD Sys Info
-> Manufacturer: coldtears electronics
-> SerialString: lcdsy
-> Is Open: True
-> IsAlive: True
-> Name: LCDsysinfo for GOverlay
-> Rev: 100
-> DeviceDesc: LCDsysinfo for GOverlay
-> HardwareId: System.String[]
-> CompatibleIds: System.String[]
-> Class: libusb-win32 devices
-> ClassGuid: {eb781aaf-9c70-4523-a5df-642a87eca567}
-> Driver: {eb781aaf-9c70-4523-a5df-642a87eca567}\0001
-> Mfg: Coldtears Electronics
-> FriendlyName:
-> LocationInformation: Port_#0001.Hub_#0005
-> PhysicalDeviceObjectName: \Device\USBPDO-12
-> BusTypeGuid: 9d7debbc-c85d-11d1-9eb4-006008c3a19a
-> LegacyBusType: 15
-> BusNumber: 0
-> EnumeratorName: USB
-> Address: 1
-> UiNumber:
-> InstallState: 0
-> RemovalPolicy: 3
-> SymbolicName: \??\USB#VID_16C0&PID_05DC#lcdsy#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
-> Connection Tests:
----> Connection OK
----> Serial: 21710012435671539336
----> FW Version: 103
----> Connection Try #2 Succeded
----> Connection Try #3 Succeded
----> Connection Try #4 Succeded
----> Errors: 0:
------------- LibUsb Utility Devices Report ------------
Dev #1: coldtears electronics - LCD Sys Info - Serial Number: lcdsy
bLength: 18
bDescriptorType: 01h
bcdUSB: 0110h
bDeviceClass: FFh
bDeviceSubClass: 00h
bDeviceProtocol: 00h
bMaxPacketSize0: 08h
idVendor: 16C0h
idProduct: 05DCh
bcdDevice: 0100h
iManufacturer: 1
iProduct: 2
iSerialNumber: 3
bNumConfigurations: 1
wTotalLength: 18
bNumInterfaces: 1
bConfigurationValue: 1
iConfiguration: 0
bmAttributes: 80h
MaxPower: 50
bInterfaceNumber: 0
bAlternateSetting: 0
bNumEndpoints: 0
bInterfaceClass: 0
bInterfaceSubClass: 0
bInterfaceProtocol: 0
iInterface: 0
------------- Listing all USB Connected Devices ------------
--> USB Root Hub
----> Service: usbhub
----> Description: USB Root Hub
----> Manufacturer: (Standard USB Host Controller)
----> DeviceID: USB\ROOT_HUB\4&6427700&0
----> Status: 0
--> USB Root Hub
----> DeviceID: USB\ROOT_HUB20\4&1828FFF1&0
----> Status: 0
--> NEC Electronics USB 3.0 Root Hub
----> Service: nusb3hub
----> Description: NEC Electronics USB 3.0 Root Hub
----> Manufacturer: NEC Electronics
----> DeviceID: NUSB3\ROOT_HUB30\5&1832EE6&0
----> Status: 0
--> USB Root Hub
----> DeviceID: USB\ROOT_HUB\4&2B98EF05&0
----> Status: 0
--> USB Composite Device
----> Service: usbccgp
----> Description: USB Composite Device
----> DeviceID: USB\VID_046D&PID_C07D\0F60346E3232
----> Status: 0
--> USB Input Device
----> Service: HidUsb
----> Description: USB Input Device
----> Manufacturer: (Standard system devices)
----> DeviceID: USB\VID_046D&PID_C07D&MI_00\6&21817A47&0&0000
----> Status: 0
--> HID-compliant mouse
----> Service: mouhid
----> Description: HID-compliant mouse
----> Manufacturer: Microsoft
----> DeviceID: HID\VID_046D&PID_C07D&MI_00\7&B216E64&0&0000
----> Status: 0
----> DeviceID: USB\VID_046D&PID_C07D&MI_01\6&21817A47&0&0001
----> Status: 0
--> HID Keyboard Device
----> Service: kbdhid
----> Description: HID Keyboard Device
----> Manufacturer: (Standard keyboards)
----> DeviceID: HID\VID_046D&PID_C07D&MI_01&COL01\7&2EF8AC26&0&0000
----> Status: 0
--> HID-compliant consumer control device
----> Service:
----> Description: HID-compliant consumer control device
----> DeviceID: HID\VID_046D&PID_C07D&MI_01&COL02\7&2EF8AC26&0&0001
----> Status: 0
--> HID-compliant device
----> Service:
----> Description: HID-compliant device
----> DeviceID: HID\VID_046D&PID_C07D&MI_01&COL03\7&2EF8AC26&0&0002
----> Status: 0
----> Service:
----> DeviceID: HID\VID_046D&PID_C07D&MI_01&COL04\7&2EF8AC26&0&0003
----> Status: 0
----> Service:
----> DeviceID: HID\VID_046D&PID_C07D&MI_01&COL05\7&2EF8AC26&0&0004
----> Status: 0
----> DeviceID: USB\VID_1532&PID_011C\5&1CAA961E&0&2
----> Status: 0
--> Razer BlackWidow
----> Description: Razer BlackWidow
----> Manufacturer: Razer Inc
----> DeviceID: USB\VID_1532&PID_011C&MI_00\6&32E45C67&0&0000
----> Status: 0
----> DeviceID: HID\VID_1532&PID_011C&MI_00\7&310793CD&0&0000
----> Status: 0
----> DeviceID: USB\VID_1532&PID_011C&MI_01\6&32E45C67&0&0001
----> Status: 0
----> DeviceID: HID\VID_1532&PID_011C&MI_01&COL01\7&D30560B&0&0000
----> Status: 0
----> Service:
----> DeviceID: HID\VID_1532&PID_011C&MI_01&COL02\7&D30560B&0&0001
----> Status: 0
----> Service:
----> DeviceID: HID\VID_1532&PID_011C&MI_01&COL03\7&D30560B&0&0002
----> Status: 0
----> Service:
----> DeviceID: HID\VID_1532&PID_011C&MI_01&COL04\7&D30560B&0&0003
----> Status: 0
----> Service:
----> DeviceID: HID\VID_1532&PID_011C&MI_01&COL05\7&D30560B&0&0004
----> Status: 0
----> DeviceID: USB\VID_1532&PID_011C&MI_02\6&32E45C67&0&0002
----> Status: 0
----> DeviceID: HID\VID_1532&PID_011C&MI_02\7&24F3E250&0&0000
----> Status: 0
--> USB Root Hub
----> DeviceID: USB\ROOT_HUB20\4&5E0D3C3&0
----> Status: 0
--> Realtek RTL8191SU Wireless LAN 802.11n USB 2.0 Network Adapter
----> Service: RTL8192su
----> Description: Realtek RTL8191SU Wireless LAN 802.11n USB 2.0 Network Adapter
----> Manufacturer: Realtek Semiconductor Corp.
----> DeviceID: USB\VID_0BDA&PID_8172\00E04C000001
----> Status: 0
--> USB Root Hub
----> DeviceID: USB\ROOT_HUB\4&22DCF096&0
----> Status: 0
----> Status: 0
--> USB Root Hub
----> DeviceID: USB\ROOT_HUB\4&25712375&0
----> Status: 0
----> DeviceID: USB\VID_0DBA&PID_3000\DIGIDESIGN
----> Status: 0
--> Digidesign Mbox 2 Firmware Updater
----> Service: MBX2DFU
----> Description: Digidesign Mbox 2 Firmware Updater
----> Manufacturer: Digidesign
----> DeviceID: USB\VID_0DBA&PID_3000&MI_00\6&7763CE3&0&0000
----> Status: 0
--> Digidesign Mbox 2 Mini Audio
----> Service: DGUSBAP
----> Description: Digidesign Mbox 2 Audio
----> DeviceID: USB\VID_0DBA&PID_3000&MI_01\6&7763CE3&0&0001
----> Status: 0
--> Digidesign Mbox 2 Mini MIDI
----> Description: Digidesign Mbox 2 Midi
----> DeviceID: USB\VID_0DBA&PID_3000&MI_06\6&7763CE3&0&0006
----> Status: 0
--> USB Root Hub
----> DeviceID: USB\ROOT_HUB\4&14E368E2&0
----> Status: 0
--> Corsair Integrated USB Bridge (USB)
----> DeviceID: USB\VID_1B1C&PID_0C04\5&16E221C7&0&2
----> Status: 0
--> Corsair Integrated USB Bridge (HID)
----> Service:
----> DeviceID: HID\VID_1B1C&PID_0C04\6&46BAAA2&0&0000
----> Status: 0
--> USB Root Hub
----> DeviceID: USB\ROOT_HUB\4&3AE06BE8&0
----> Status: 0
Thanks in advance for any help guys
eric78
Re: Not working
Postby eric78 » Fri Jan 22, 2016 4:05 pm
From log I'm still getting this
22/01/2016 16:01:41:GOverlay successfully inited
22/01/2016 16:02:47:LCDSysInfo - Init
22/01/2016 16:02:47:LCDSysInfo - Error opening device
22/01/2016 16:02:48:LCDSysInfo - Init
22/01/2016 16:02:48:LCDSysInfo - Error opening device
Driver is installed too
eric78
Re: Not working
Postby TheLaGmAn » Fri Jan 22, 2016 4:36 pm
how old is your unit and what version of goverlay were you running when it worked?
Re: Not working
Postby eric78 » Fri Jan 22, 2016 4:51 pm
TheLaGmAn wrote:how old is your unit and what version of goverlay were you running when it worked?
Hi there
I bought new one LCDSysInfo few weeks ago on ebay there,old unit has been sold with my old PC and version I've run is 1.4.2 this I know for sure as I've still my old profiles for that
eric78
Re: Not working
Postby eric78 » Fri Jan 22, 2016 5:08 pm
eric78
Re: Not working
Postby TheLaGmAn » Fri Jan 22, 2016 5:11 pm
Sorry, not quite following you.
This unit you have the issue with is only 2 weeks old? and has beeen working with an old pc for two weeks on 1.4.2?
Re: Not working
Postby eric78 » Fri Jan 22, 2016 5:18 pm
TheLaGmAn wrote:Sorry, not quite following you.
Hi there
Sorry for misunderstanding.I bought this unit 2 weeks ago,this unit has come today by post and I wanted to use this unit but as above you see,I've issue to run or use this unit
My previous unit I've sold with my old PC there and this is new unit which I've right now
Hope this helps there
eric78
Re: Not working
Postby TheLaGmAn » Sat Jan 23, 2016 12:07 am
Im suspecting that your unit is faulty.
Contact the ebay seller (which is the manufacturer) and tell him your device isnt recognized by any computer and the serialstring of the unit seems to be wrong as discussed in this forum, send him this piece of info.
-> Pid: 1500
-> Vid: 5824
The serialstring "lcdsy" should be "lcdsyz", thats why its most likely not working, but probably not only just an issue of that text, its an issue of the unit having a diff piece of software on it.
Sorry about this, i know you been waiting for two weeks to get one, but contact him so you can get a replacement
Re: Not working
Postby eric78 » Sat Jan 23, 2016 12:23 am
TheLaGmAn wrote:Im suspecting that your unit is faulty.
-> Pid: 1500
-> Vid: 5824
Hi there
That's OK,my friend(he bought this for me) will contact seller tomorrow and he will send him message regarding this and I will point him to this thread if this does help to resolve this
My previous unit has been perfect and never have issue with this unit at all,when I tried to install the driver for this unit I've few issues with disabling/enabling the Digital signing etc and after few tries finally unit has been recognized under Device Manager there
Thanks again in advance
eric78
Re: Not working
Postby LeChuck » Tue Feb 16, 2016 10:59 pm
eric78 wrote:I bought this one there
http://www.ebay.co.uk/itm/USB-2-8-TFT-L ... 1004607232
This display is not compatible with GOverlay.
It say in the text like
If you need a more powerful LCD device for displaying other information, please see LCDsysinfo for GOverlay
and
This item is NOT compatible with GOverlay. The device which is compatible with GOverlay is available HERE : "LCDsysinfo for GOverlay"
LeChuck
