Not working
Re: Not working
Postby TheLaGmAn » Fri Feb 19, 2016 5:11 pm
I totally missed that link from eric, lechuck is totally correct, that unit isnt compatible with GOverlay so it wasnt a faulty unit at all.
Re: Not working
Postby Kabron » Sat Apr 15, 2017 1:55 pm
Not working on two desktops. Works on other PCs.
Log and report attached. Goverlay runs as admin.
Goverlay.zip
(5.16 KiB) Downloaded 478 times
Kabron
Re: Not working
Postby TheLaGmAn » Sat Apr 15, 2017 5:21 pm
the report shows that the unit is okay, so the issue is on the software side with your PC, probably with the usb library.
1- Try connecting to a different port.
2- Try using a different cable if you are not using the same from the working computer.
3- Try uninstalling and installing libusb again
4- Try running GOverlay as admin
5- Try uninstalling the driver from the "Device Manager", rebooting, and re-installing it again
Re: Not working
Postby Kabron » Sun Apr 16, 2017 12:06 pm
Solved by decreasing dll, sys versions from 1.2.6.0 to 1.2.2.0
Kabron
Re: Not working
Postby TheLaGmAn » Sun Apr 16, 2017 2:03 pm
Great! thanks for the feedback, so its an issue with the new libusb library it seems
