Sure, i answered by email because he contacted me thru support,
here is the email on how to create a custom CPUInfoBox without making new plugins, make sure you have the latest beta because you need the imagebar element to create it.
What you can do, if you dont have programing skills to create a plugin is to play with all the available elements GOverlay provides to create a new CPUInfoBox, i will give you the basics so you can have an idea, im doing this by memory so it might not show 100% accurate but its totally possible to do it like this.
1- Add an image graph sensor
Set the values for the image from 0 to 100 as:
0:% 140
1%: 141
10%: 142
20%: 143
30%: 144
40%: 145
50%: 146
60%: 147
70%: 148
80%: 149
90%: 150
100%: 150
Set minimum value to 0 and max value to 90 (This will make the temperature graph to show empty when the temp is 0 and max when the temp is 90, but since this graph is actually TWO graphs together - see the second element- our 100% would be one part of the graph, so when the temperature is 90 degrees, it will actually show like half of the graph filled since we put two graphs together)
Now Select your temperature sensor
2- Add another image graph sensor
0%: 151
1%: 152
10%: 152
20%: 153
30%: 153
40%: 154
50%: 154
60%: 155
70%: 155
80%: 156
90%: 157
100%: 158
Set minimum value to 90 and max value to 120 (When the temp is below 90, it will show as a turned off graph, when temp is above 90 -the previous graph will be full- now this graph will start to light up, up to 120 degrees as 100%.
What you just did is create the same graph that shows in the CPUInfoBox, what you need to do is to place the two elements correctly since the second one should fit in the top-right side of the 1st element
Something like this:
[Eelement2]
[E1]
And move it 1 pixel at a time to make a perfect match.
Then add the individual sensors and use the numbers font to show the fan and other info you want to show and place it where it would be like in the CPUInfoBox.
then you are just missing the texts and "%" icons that you can add by adding a background icon image.
If you can, once you have your setup done, please share it with us with a photo of the device
