Hi guys
I've downloaded profiles which I've found on this forum,but when I try to change anything in GOverlay I'm getting this error: GOverlay found an error,message is:Object reference not set to an instance of an object.Continue ? I've check the logs too where I'm getting strange AIDA64 error like this
31/07/2015 00:23:49:LCDSys - Sensor 1411842788.05428 (sensor: AIDA:Value.TNB malfunction : Object reference not set to an instance of an object.
31/07/2015 00:23:49: at t.b()
31/07/2015 00:23:49:LCDSys - Sensor 1411842930.26042 (sensor: AIDA:Value.TSB malfunction : Object reference not set to an instance of an object.
31/07/2015 00:23:50:LCDSys - Sensor 1411842788.05428 (sensor: AIDA:Value.TNB malfunction : Object reference not set to an instance of an object.
31/07/2015 00:23:50: at t.b()
31/07/2015 00:23:50:LCDSys - Sensor 1411842930.26042 (sensor: AIDA:Value.TSB malfunction : Object reference not set to an instance of an object.
Thanks,Eric
