How to change the Skype splash notification picture?
Postby ebhsimon » Sun Mar 29, 2015 12:24 pm
Right now it turns the whole screen blue for about half a second, and while it's great and I notice it, I can't help but feel it doesn't look very refined.
Is there some way I can add my own picture to replace the uniformly blue splash notification?
ebhsimon
Re: How to change the Skype splash notification picture?
Postby TheLaGmAn » Sun Mar 29, 2015 2:08 pm
There is no way to change that behavior, the reason for the color bg is because an image takes too long to show, a whole bg-color fill is a lot faster.
You can disable the splash if you dont want to see it anymore tho.
