Counter-Strike 2 Dashboard: v1.1
Profiles shared thru the GOverlay Web Portal for GOverlay Plus
Postby Clone003 » Tue Jan 30, 2024 4:06 am
This is my profile using the new CS2 plugin that TheLaGmAn developed.
You have to enable the plugin, and have the gamestate integration .cfg in your CS2 cfg folder for this to work!
It uses the CS2/CSGO Game State Integration feature.
https://developer.valvesoftware.com/wik ... ntegration
It will show the stats for the player or the player you're currently spectating.
The only customization I added was the background.
There's the default CS2 splash screen, and another background which changes depending on the map you play.
Enable and disable the elements to use the background you want.
The grenades have 3 transparency states: equipped, holstered, and not bought.
The armor logo adds a helmet when you buy one.
The team logo changes depending on the team you're on.
The current ammo in clip for the primary and secondary is always displayed.
The current equipped weapon will display its ammo in clip and ammo reserve.
I believe there's a current bug in the plugin that doesn't detect the CT's incendiary grenade well, but the T Molotov is fine.
Clone003
Re: Counter-Strike 2 Dashboard: v1.0
Postby Clone003 » Tue Jan 30, 2024 4:07 am
v1.1: Health Bar background is now red, just like in the game. Sadly no fade effect just like the game
Clone003
Re: Counter-Strike 2 Dashboard: v1.1
Postby TheLaGmAn » Mon Feb 05, 2024 5:01 pm
awesome profile, thanks for sharing
Return to Shared Profiles
