Ryzen and GeForce Display: 0.1
Profiles shared thru the GOverlay Web Portal for GOverlay Plus
Postby Clone003 » Tue Jan 02, 2024 9:33 pm
Inspired by user vinsgosselin's 'Ryzen 3900X and RTX 2080 Superprofile.
That profile also inspired and spawned many profiles for the LCDSysInfo 3.5"
viewtopic.php?f=6&t=1615
Still a work in progress in terms of the layout and alignmentbut I'm currently happy with how it is.
Many things are eyeballed due to lazyness :)
The sensors displayed are the ones I really care about seeingso I probably will not add more sensors on request.
Layout suggestions/ideas are always welcome!
Used HWInfo as the source for the sensors
You will need to configure the individual sensors. (Sensor source and Max values)
I tried my best to label the elements properly so it's understandable.
Download/Upload Bar gauges will need more configuration since I messed with the output value on HWInfo itself on my computer.
Alternative Nvidia logo provided. Just enable and disable the according elements in the list.
Disable/Enable is located in the 'Size and Positionsection of the element.
If there's demandI may be willing to adapt it to a different setup (ex. Intel Radeon).
Logos downloaded from https://worldvectorlogo.comand https://seeklogo.com/
Icons from mdi https://pictogrammers.com/library/mdi/
Converted black logos to white using Inkscape.
Clone003
Re: Ryzen and GeForce Display: 0.1
Reseved. Just in case
Clone003
Thank you
Postby fetynelson37 » Sat Jan 06, 2024 7:23 pm
Thanks for your profile
fetynelson37
Thank you
Postby fetynelson37 » Sat Jan 06, 2024 9:36 pm
fetynelson37
Thank you
Postby fetynelson37 » Sat Jan 06, 2024 11:00 pm
fetynelson37
Thank you
Postby fetynelson37 » Sat Jan 06, 2024 11:16 pm
fetynelson37
Thank you
Postby fetynelson37 » Sun Jan 07, 2024 9:54 am
fetynelson37
Thank you
Postby cubian » Sun Jan 07, 2024 2:34 pm
cubian
Thank you
Postby kbuchwitz » Wed Jan 10, 2024 9:12 pm
kbuchwitz
Thank you
Postby m.liermann » Wed Jan 10, 2024 11:20 pm
m.liermann
Return to Shared Profiles
