rivaturner
rivaturner
Postby fetynelson37 » Sun Mar 17, 2024 2:59 pm
hello I have a small problem with rivatuner.
I see it in sensors viex but not in the sensors of my profile. I have already reinstalled but nothing to do
17/03/2024 15:58:02:GoverlaySocket - UpdateAndGetActiveSensors - RTSS Error - Exception: Impossible de charger le fichier ou l'assembly 'RTSS_Hook2.dll' ou une de ses dépendances. n’est pas une application Win32 valide. (Exception de HRESULT : 0x800700C1)
fetynelson37
Re: rivaturner
Postby TheLaGmAn » Sun Mar 17, 2024 3:19 pm
Can you check you have the file
MSVCR110.dll
in your goverlay folder? also, right click on it, properties and see if the DLL is blocked
If that doesnt work, can you try downloading:
https://github.com/lucasg/Dependencies/ ... elease.zip
and runn DependenciesGui.exe, click on file > open > and select the RTSS_Hook2.dll and then paste a screenshot here of the left part of the window, to see which dependency is failing
Re: rivaturner
Postby fetynelson37 » Sun Mar 17, 2024 5:20 pm
fetynelson37
Re: rivaturner
Postby fetynelson37 » Sun Mar 17, 2024 5:22 pm
fetynelson37
Re: rivaturner
Postby TheLaGmAn » Sun Mar 17, 2024 6:47 pm
can you post the same properties of RTSS_Hook2.dll ?
Re: rivaturner
Postby fetynelson37 » Sat Mar 23, 2024 8:30 am
sorry for the delay I was traveling this week
fetynelson37
Re: rivaturner
Postby TheLaGmAn » Sun Mar 24, 2024 9:55 pm
we will need to do a teamviewer/anydesk session to check it out because everything seems fine.
Can you send me an email to support@goverlay.com and we will coordinate a time
