Problem : Clock threshold doesn't seem to work
Postby jon.191023 » Wed Feb 21, 2024 8:00 pm
I'm actually trying to define a threshold parameter for the Internal clock sensor with HH:mm:ss format :
But it doesn't seem to work at all as you can see below :
I don't know if it's a sensor problem like before or an incorrect threshold parameter from my side because the sensor data format is like this : 00:00:00
Once again could you help me pls with this situation.
jon.191023
Re: Problem : Clock threshold doesn't seem to work
Postby TheLaGmAn » Thu Feb 22, 2024 2:45 pm
mm yeah, that wont work because the hour in that case is a string, so its not handled as a number. Let me see if there is anything i can do for that
Users browsing this forum: Majestic-12 [Bot] and 1 guest
