Request : Possibility to implement a sensor text module
Postby jon.191023 » Thu Feb 15, 2024 6:54 pm
Actually we have the possibility to modify an icon or an Image in relation with a specific sensor data but I'm actually looking for a way to modify a text only but I don't find a way to do t hat with existing tools.
The simple way in first time would be to take a basic sensor module with threshold parameters for modifying his text field but I don't find the possibility to hide the sensor value in that case.... Is that possible actually ?
jon.191023
Re: Request : Possibility to implement a sensor text module
Postby TheLaGmAn » Thu Feb 15, 2024 7:00 pm
if you want to change text, you could do it with the visual scripting, condition math and format the output value, wouldnt that be what you need?
Postby jon.191023 » Thu Feb 15, 2024 8:14 pm
TheLaGmAn wrote:if you want to change text, you could do it with the visual scripting, condition math and format the output value, wouldnt that be what you need?
Ok I finally succeed thx to you. Didn't see the format option from string operation in visual scripting.
It's perfectly working now.
Thx a lot once again .
jon.191023
